Reference planes and beams
Hello everyone,
I am drawing a building in Revit, and I am having some issues while trying to model a beam that is attached to a sloped slab. The way that I done this was throgth the creation of an reference plan that would have the inclination that I want, and then I drew the beam with this reference plan attached. The problem with this is the fact that I had to delete the beam that I already had drew because she wasn´t sloped, and drew it again, but now with a reference plan attached.  My doubt is if I cant do this without having to delete the beam and then re-drew it using the reference plan that I want.
Best regards
awes
Select beam. Right click. Select detach from plane. Select ref plane. Select Align (AL). Select side of beam to align with.
@awes, thanks for the help. I tryed what you said but the option " dettach from plane" isn´t avaible... It could be something that I aint doing ritgh.
Best regards
twebb4CYQY
If you manually input a start and end level offset for any beam, it will detach from it's plane.
@twebb4CYQY, thanks a lot for the help.
best regards
