Rebaring using revit
NERDASORUS
NERDASORUS
Hello
Is revit an adequate program for rebaring complex projects?? I'm using tekla structures and although it's very capable, revit is much faster and much more user friendly.
So should I start
ennujozlagam
you can refer to this LINK and see if helps. thanks
shefypattambi
@NERDASORUS
Unless you are backed up with addins like Sofistick or Graitec or Idat or CAD RCDC..please stick with Tekla.!!
Revit is much user friendly but it will not be fast as Tekla once you model all the rebar. Of course, it depends on your project's complexity and size.
ovidiu_paunescu
Hi @NERDASORUS
Are you looking at also learning Revit in general?
If yes, I would recommend the essential trainings for architecture and structure on Linkedin Learning.
For rebar, the resources are kind of scattered, from what I saw online. Some basic placement and modification information is available in the structure training on linkedin learning
I can also recommend the two classes I presented at AU, which deal with basic functionality, tips and tricks, as well as the latest features related to rebar.
https://www.autodesk.com/autodesk-university/class/Rebar-Modeling-Revit-Keep-It-Check-2019
https://www.autodesk.com/autodesk-university/class/Tips-and-Tricks-Effective-Rebar-Detailing-Revit-2...
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
