Rebar view - unobscured and solid
is there a way to set red squared values to default?
I just keep losing time to set these parameters manually!
Regards!
jeroen_vanmassenhove
Interesting, I'd like to know that as well.
On the other hand, you can draw all of your rebar, get a 3D view and select everything, filter out the rebar in the bottom right corner. Then you can set that setting for all of them at once.
Kind regards
@jeroen_vanmassenhove
Hi,...
yes I know that,..but what if I have rebar groups, and variable rebar sets?
Regards!
ovidiu_paunescu
Those can be set per each bar instance, regardless of it being a Single bar or a Set (regular or varying).
By default, unobscured is set on bar creation in the view where the bar was created.
Section views get the unobscured check by default.
Solid cannot be set by default, it can only be set manually after the bar was created and for the view(s) where you want it to show as solid.
Dynamo or a Revit add-on could be used to set the parameters without selecting all bars.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Ok,...
Thank you Ovidiu for clarifying that.
