Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Rebar Tag leads own lifte when copying or pasting to similar rebar
3 REPLIES 3
pieter.zeenaeme
482 Views, 3 Replies
pieter.zeenaeme
Rebar Tag displaces, moves or is unable to be placed when copying or pasting to similar rebar.
See video
See video
Labels (1)
3 REPLIES 3
Ahmed_Muharram
It's a very annoying problem.... i think if you canceled the leader it will be ok when copy
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
BIM Manager
ovidiu_paunescu
Hi @pieter.zeenaeme
In Revit 2020, I can reproduce your result, only when copying the beam, rebar and tags to the side.
If I copy just the tags over another beam it works.
In Revit 2021, it works properly.
Could you share a sample file?
If you have 2021 installed, could you try the same steps?
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Hi @pieter.zeenaeme
pieter.zeenaeme
@ovidiu_paunescu
Solved in Revit 2021 ☝️
Thanks for the advice
@ovidiu_paunescu
