Rebar Tag displaces, moves or is unable to be placed when copying or pasting to similar rebar.
See video
Solved by ovidiu_paunescu. Go to Solution.
It's a very annoying problem.... i think if you canceled the leader it will be ok when copy
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
In Revit 2020, I can reproduce your result, only when copying the beam, rebar and tags to the side.
If I copy just the tags over another beam it works.
In Revit 2021, it works properly.
Could you share a sample file?
If you have 2021 installed, could you try the same steps?
