Rebar Tag leader
Rebar Tag leader
markkibui101
Rebar Tag leader
markkibui101
Hi, how can I modify a rebar tag leader to go all tthe way under the tag name such that it acts as underline too like you would in Autocad.
to this...
ovidiu_paunescu
Hi @markkibui101
You can create an invisible box with a visible line under the text, in the tag family.
If the visible line is at the center (on the vertical), the leader will attach to it when placing the tag in the project.
Tip: to see the planes inside the tag family, go to visibility graphics overrides and enable annotation categories.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
markkibui101
Your solution worked. Thank you.
