Rebar Tag - How to display partial lengths in tag
AECmanuel
AECmanuel
Hi hello, I have waited a long time to be able to include in the tag all the individual lengths for a rebar. So far i have been able to include only lengths that are specified without a formula, more specifically, i can´t show the dimension associated to the hooks of the rebar.
Am i doing something wrong or is no t possible so far  in REVIT?
Regards
semi
Every rebar shape length has it's own length parameter.
Rebar shape 21 f.e. has 3 rebar lengths A - B - C If you put those parameters in a tag, they show up the way u want.
AECmanuel
Hi, yesterday afternoon i could finally do it. The trick is that you have to get into the family, export that parameter to the shared parameters file and then you should create the parameter in the tag family.  If you don´t do it that way the partial lengths dont show in the tag.
Regards
AECmanuel
Now, another doubt, just if someone knows how to....
To create a general TAG that doesn´t show a zero value if the bar doesn´t have a value in that partial length. Right now i have many different tags for the different combinations o rebar shapes.
Hope that i explained correctly.
ArmanMargaryan
@AECmanuel I hope this helps you.
https://autode.sk/3tmXLIH
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
AECmanuel
Excelent!!!!!!!! Just Perfect!!!
Thanks a lot
ArmanMargaryan
If the above reply answers your question; Please mark it with ACCEPT SOLUTION.
Arman Margaryan
Linkedin | Facebook
