Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Rebar Splice Dimensioning - Revit 2025
8 REPLIES 8
Message 1 of 9
farzanbayat74
493 Views, 8 Replies
I can't snap to rebar end to draw my dimension line to show overlap length.
Tags (3)
Labels (1)
8 REPLIES 8
Message 2 of 9
can you share the file?
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
Message 3 of 9
@Ahmed_Muharram
I got angry and closed it without saving.
Rebar is created using free form tool.
Message 4 of 9
I have tested and it's working
just check you have a section that shows all the rebar set and use tab to hover the selcetion
BIM Manager
Message 5 of 9
Message 6 of 9
antonbond
in reply to: farzanbayat74
the solution to your & that 'issue' is to use Lbars (or Ubars) with hooks at ends rather than rebar shapes with multiple segments. If what you show in your snip is a typical slab edge bars, I'd suggest model them with hooks. You always can override hook lengths if required
Message 7 of 9
farzanbayat74
in reply to: antonbond
@antonbond
I used sketch tool from free form rebar to draw continuous rebar for this beam:
Do you have a solution for it?
Message 8 of 9
antonbond
I don't follow. How does this last question relate to the one you asked before?
anyways, it can be a shape driven bar in your last image. No need to use Freeform I'd say. when you sketch just pick shape driven. There're multiple ways you can model a bar like that & sketching is one of them, so you're doing all right
Message 9 of 9
farzanbayat74
@antonbond
The reason I couldn't snap to rebar end, was because I used free form rebar, as a result the rebar plane and dimension plane were perpendicular and I couldn't snap to rebar end (current limitation in Revit).
So I was looking for another way except sketching, to draw that rebar to solve my problem.
Forma Design Contest
Technology Administrators
