Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Rebar showing in U-shaped foundation slab...... but not correctly
1 REPLY 1
kantoor
127 Views, 1 Reply
Hello all,
I've made a U-shaped concrete foundation in which I added rebar (Structure => Area).
In my section or detail view the rebar is showing. But not the way I want it to show.
In the attached picture the rebar in the red circle should not be shown because it has no sense to be shown there because it should not exist there.
Does anyone have a solution how to get rid of this section of rebar in the section and detail view?
1 REPLY 1
jay_colcombe
in reply to: kantoor
Are the elements in the background at an angle?
As it is Area reinforcement is it fully with the U- Shaped elements? Did you get warnings reinforcing was outside its host?
It looks like the View is showing elements in the background.
From the Properties Palette, Change the View Depth to a lesser value to reduce the far clip offset and the Clip Range also
Jay Colcombe
Autodesk Certified Instructor
