Hi guys
I am working on rebar schedule, while scheduling I found some rebar shapes are not showing A, B, C... G values. I have tried duplicating rebar shape, initially when I faced this problem that time, I deleted all duplicate rebar shape and then it was working but now I have tried that as well but no success.
please help.
M_03
Revit Version-2024
Please check your Schedule Fields as sometimes there are duplicates of A, B, etc...
So you may need to review the Duplicate and see the Parameters for these references and see if they are repeated in the Schedule.
Also in previous versions of Revit if there were multiple values for a filed it would produce a Blank Cell whereas in newer releases it States "Varies" could it be there are numerous Values?
Hi, I have tried whatever u said, but there is no duplicate parameter in my rebar schedule, I have made these shape by using Stright bar then gave 90-degree hook, so Revit have created new shape type. This problem prevails in all the new shape which Revit created automatically.
I have checked itemize as well but no succes, shared snip for same.
Revit Version-2024
Hi jay
I have found the problem there are duplicate parameters (2x A B C D E...), which u said in Ur first reply. can u help me with what should I do.
Try adding them all in AA, BB, CC, etc.....
And then determine which ones give the correct results and then remove the ones that do not.
I would possibly reinstall all shapes to bet back to square one!
From the Insert Tab
You can hold down shift to select them all and reload back into the project and override existing Parameters and shapes to get back to the original famailes/shapes
