Rebar Schedule on layout
is there a way to put rebar schedule for "layout only" rebar??? What I mean is that if I have for example rebar positions 2, 3, 4, 6, 7 and 18 on the layout drawing, I would like to have rebar schedules for those positions on that specific layout!!!
Regards
aleksei.tkachenko
Hello
You can use parameter Partition for each layout in you project. Then in rebar schedule you just filter rebars by partition.
OK! How do you access this menu?
aleksei.tkachenko
By clicking on "Filter" when you have your schedule-window open
Thanks!
I guess, when I started drawing rebar I had to add Partition descriptions??? When I open my schedule properties I have this:
Is there a way around?
Regards!
aleksei.tkachenko
You have to fill in partition parameter for each rebar in your modell in order to filter the schedule. You can choose all the rebars that you want to include in the schedule and add Partition name to them. Then this Partition name should show up in Filter-tab.
Thank you!
