Rebar not visible in plan view (looking up) when using plan region
pieter.zeenaeme
pieter.zeenaeme
Rebar not visible in plan view (looking up) when using plan region and set the view range above the original view range. See video
MartinGTE
Have you opened the visibility states on the bar and chose what view you would like to see it in?
pieter.zeenaeme
I think the problem is not the visibility state.
The problem is Revit limitations (looking up, plan region, view range above original view range, wall stays visible, rebar dissapears)
I added the video from scratch (Autodesk Structure template) so it can be easy reproduced...
Orsolya.Balazs
Autodesk Support
Autodesk Support
Hi @pieter.zeenaeme ,
Thank you for the great video.  Following your steps I have received the same as you. I have documented this issue to the development for analysis to clarify if this may need enhancements.
Orsolya Balazs
Product Support Analyst - AEC
Autodesk, Inc.
