Rebar missing when imported into Twinmotion
BJX916_XUANWU115
BJX916_XUANWU115
Hi everyone, not sure if this is the right place to post this issue.
Has anyone ever tried to import rebars into Twinmotion? I just installed Twinmotion today and wanted to make a construction sequence video, but when I imported the model into Twinmotion, only 4 bars are showing, others are all missing. I imported Revit snowdon towers sample structural model, all the rebars are missing.
I tried to do some research online, but got little information, and I saw someone post the similar question on Twinmotion Forum, but didn't get the answer, so I tried to post it here and see whether I can get any luck to get a solution or some advice.
I am using Revit 2025 and Twinmotion 2024.1.2
Thanks in advanced.
jay_colc
I do not think it is possible but I will check and confirm when at the PC.
Jay Colcombe
Autodesk Certified Instructor
BJX916_XUANWU115
thank you very much.
jay_colc
Tried loads of methods but could not get it to work whatsoever so I would state it’s not a feasible option!
Jay Colcombe
BJX916_XUANWU115
Hi, we found a solution. We exported the Revit model to a fbx. file, then imported to Twinmotion, the rebars are fine.
zaex
Community Visitor
Community Visitor
BRO U SAVE MI LIFE 😭👏👏👏🙏 THNKS FOR TIP
