REBAR Length and Overlap
Can someone please tell me if/how we can specify the Length of bars available for the project and assign a overlap length?
I.e. I'm making a 30m reinforced concrete beam with straight bars in it. The problem is Revit shows a single bar Length to be 30m (which is unrealistic) whereas I have bar Length of 12m available and need to put 1.8m overlap as per standard.
awes
You can do it manually by defining a 12 m long rebar and the copying it with 1.8 m overlap.
There are third party apps that can handle the overlapping based on your configuration.
ovidiu_paunescu
Hi @Anonymous
If you are using Revit 2020.1 or newer, you can also constrain the bars together and specify an overlap.
https://youtu.be/yqD0PxBJA_M
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Alan.johnson1970
Graitec BIM Designer plug-in has a lapping tool
you can specify lap length, lap type (lap, Coupler, cranked) and stagger lapping
https://www.graitec.com/advance-bim-designers/reinforced-concrete-designer/
AJ.
