Announcements
Rebar family creation
Hi all,
I am a Revit Architecture Designer, I got a new task in Revit Structure.
I created a new rebar family using metric rebar shape template,but it showing some shape status error. How can i remove the error?
Replies (9)
mĂșinteoir
please share family and error?
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
family is Metric Rebar shape template
ovidiu_paunescu
Hi @Anonymous
You need to associate a shared parameter to each of those dimensions (just like you would associate one to a dimension in any other revit family).
After associating each dimension to a shared parameter (A, B, C..), go to Family Types and add a default value to each parameter associated with a dimension.
More about editing rebar shape families here
See the example below, for the default 00 shape in the metric structural template
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
shefypattambi
Hi @Anonymous,
did you really wanna create this rebar shape as a family ?
 this shape is already available in revit depending upon the rebar family shape you loaded in to the revit template. for example if you are using British template search for rebar shape code 21 in your family - rebar shape category tree.
if you are facing difficult to find it. please download this shapes and insert into your project.
http://blogs.autodesk.com/bim-and-beam/2016/12/19/rebar-shape-images-in-revit/
The content that is used for this small model can be downloaded from
https://revitbeyondbim.wordpress.com/2016/12/15/rebar-shape-images-in-revit/
 Hi shefypattambi ,
I want to create these kind of rebar..I think this type rebar is not available in template..
shefypattambi
Hi @Anonymous,
This kind of rebar you can simply draw inside the revit project itself. No need of any custom rebar shape family for that.
shefypattambi
After doing the entire process, still Im getting shape error...here im attaching the error. Please look at it and help me to creat a rebar shape family.
PavelAnd
Hi @Anonymous. You need to dimension the rebar shape, not the reference plane.
Best regards, Pavel Plotitsyn.
Type a product name
