I have 2 footings the lower one is plain concrete footing and the upper one is the reinforcement concrete footing
i can't rebar the upper one because revit neglecting its bottom cover face and sure i don't want to rebar the lower fotting because its a plain concrete not reinforcement, so how to reactive the footing rebar cover bottom face again?
You can try to select this "plain concrete" and then uncheck -> "structural" option.
I hope that this is going to help you,
Marek
There is also one more possible solution,
If you have joined both elements, then bottom rebar cover for your "reinforcement concrete" will be inactive. So try to unjon these elements.
Marek
Unfortunately the isolated footing not including the property 'structure' so i can't use it, and i didn't join the footings but i think revit did it automatically and joined them. i'm hoping to find a solution for that.
but thank you for trying to help me Mark.
Hello Ahmed,
The two footings will join automatically when next to each other so the cover will not be visible. A workaround for this would be to leave a 1mm gap between them, now the cover should be represented in both footings.
Please tell me if this helps, also if this solution seems to be too time consuming you could send me the rvt and we'll try to find something better.
Thank you,
Cristian Simion
