Rebar - Angles near but not exactly 90 degrees
nick.seman
nick.seman
When placing a U shaped bar in a section cut at a skew through a beam I find that I can create a bend just slightly larger than 90 degrees (for example 90.75 degrees) but on the opposite side I cannot create a bend just slightly less than 90 degrees (for example 89.25 degrees).  It seems that anything between 88 degrees and 90 degrees defaults to 90 degrees.  Is there a setting somewhere that is causing this to occur ?
Ignoring of course the question of whether one would want to specify an 89.25 degree angle . . . .
Thanks;
Nick
nick.seman
