Rebar Align Command
Rebar Align Command
Rebar Align Command
Hi ,
does Revit's align command work with rebar?
Regards!
múinteoir
Yes, you can align the both sides and centre of the bar to the reference you choose.
Múinteoir
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
Thanks, you are right!
I tried to align multiple stirrups (for example 10 stirrups every 15cm) in plan view but Revit doesn't allow it. The workaround is to make multiple stirrups single and then apply align command......:-(
The same happens with all other rebar shape codes!...very annoying....
Is this a bug or am I doing something wrong???
Regards!
