R2024 Analytical Automation Errors
marcus_lyons
marcus_lyons
Hi there! I posted this question on here a few months ago, but I came across the error again in the last few days. My original question didn't really get answered, so I decided to let it go. I tried running the Analytical Automation script on my model. Even after hiding all the elements that weren't walls, beams, or columns, it seems to be throwing an error that indicates I'm asking it to work with elements outside of its scope.
Here's the model in its pared down form. Once again, all I wanted the script to do was convert these members into an analytical model that I could export to RISA Floor. In every demonstration I've seen online, the script works smoothly for this type of thing. I can't think of what the problem might be.
Here's what happens after I run the script.
Here are my inputs.
Please let me know if you have any insight. I'm eager to get to the bottom of this!
anze.kumar
Seems like your selected elements do not have any reference for adjustment - as you hidden the walls the beams cannost adjust to anything..?
maybe try testing the order of adjustment elements with unhiding the walls.
1. Beam, 2. Walls...
Once the Analytical Automation creates all Structural Elements.. delete the un-desired Analytical Walls and only keep the desired Beams.
Nader_ASSAF
Hi @marcus_lyons,
It seems that some packages are missing from dynamo.
Check the installed packages inside dynamo.
Nader ASSAF.
marcus_lyons
Which packages in particular would you recommend checking for? It appears that I have the "structural design" package that is required for the physical to analytical automation.
marcus_lyons
Tried your proposed solution and it's still throwing the same errors. I'm starting to think this may be more of a software issue. Thanks anyway!
