"Maximum spacing" bars diagonally placed
is there a way to place bars diagonally like red ones shown in the picture below? Shape code 00
Regards!
ovidiu_paunescu
Hi @Anonymous
Yes, you can model that using a varying rebar set.
Just place the set in the floor, check the varying rebar set option, edit the bar constraints and constrain the ends to the inclined element (wall).
Please note that rebar can be constrained to faces in the host + first neighbor elements (all elements that can host rebar and are joined with the rebar's host).
If you cannot choose the faces of the walls as targets for the bar ends, just join the wall and floor or re-host the rebar in the wall (pick new host).
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
@ovidiu_paunescu
Thank you!
...forgot to press "varying rebar set" ....  😞
