problems Mitering structural shapes due to detail level
Message 1 of 8
Using Revit 2019, I built a simple structural frame using C10x15.3 channels.  I want the connections at the corners to be mitered.  When I choose 2 channels and then choose the Steel/Miter command I get the following error:
The shapes for medium and fine detail levels of connected element are inconsistent.What is causing this error and how can I fix it?
Replies (7)
Message 2 of 8
YarUnderoaker
Revit doesn't recognize double sections. There is no even  idea about that at idea station. Smiley Sad
Message 3 of 8
Im not sure I understand your reply.  Attached is a screen shot of the members that I want to Miter in plan.
Message 4 of 8
Edit the family and get rid of the Medium geometry, then set the Fine geometry to show for Medium and Fine.
Message 5 of 8
Anders_HMservice
Thank you!
Had the same problem, this worked for me, i just had to delete the fine geometry as it contained rounding.
Message 6 of 8
YujinXELPG
I had the same issue and this worked for me well too!
Message 7 of 8
rohanVAMZG
Observer
Observer
How do I edit the family and get rid of the medium geometry?
Message 8 of 8
jay_colc
@rohanVAMZG Open the Family for the Channels > Change the View Settings Detail Level > Medium > Preview Visibility to ON > Select the Items > Delete
Change the View Settings Detail Level > Fine > Select the Items > Mode Panel > Visibility Settings > Tick Medium > OK > Load back into Project > Overwrite Parameter Settings
Jay Colcombe
Autodesk Certified Instructor
