Problems importing model from Robot to Revit after defining stories in Robot
I facing a problem to import a model from Robot PRO 2019 to Revit 2019, after defining storeys - I receive the "Unknown error" message. If I delete the defined storeys - the import is successful.
I am attaching a link with a clip showing the problem.
https://dox.abv.bg/download?id=1e052f3d76
Best Regards!
Shisho
jaroslaw.szwarkowski
Observer
Observer
Hi Shisho.
Could you send your example again. The link You provided does not work. We are not able to repeat and define where the error occurs.
Regards
Jaroslaw
