Good morning,
I don't understand why the visual rendering between Revit and Autocad is not the same.
However, I am in solid ACIS and not in polymesh, is there a setting that I am forgetting?
If you have a lead, thanks in advance.
The file comes from an IFC (client), I link it in Revit then I export in DWG
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
