Problem with the Steel Connections Panel in Revit 2026 (Blank Window)
angelapd828
Observer Observer
Message 1 of 8
angelapd828
Observer
Observer
I am working with Autodesk Revit 2026 using a Steel structural template.
The problem occurs when trying to use the Steel structural connections.
When I open the Connections panel, the window appears completely blank, showing no available connections.
Symptoms
The Connections panel opens normally in Revit.
However, no available connections are displayed.
The window remains completely blank.
No catalog or list of connections appears.
Checks performed
I confirmed that the Steel Connections folders are complete in the installation.
I tried the solution Autodesk suggests for a similar problem, but it did not resolve the issue.
Question
Is there a reason why Autodesk Steel Connections isn't loading connections in Autodesk Revit 2026 even though the system files are present?
Are there any recommended procedures for resetting or rebuilding the structural connections catalog so that they display correctly again?
Replies (7)
Message 2 of 8
angelapd828
Observer
Observer
This is the image of the connection diagram; Autodesk only let me upload 3 files.
Message 3 of 8
jay_colc
Have you installed the Content as this can impact the Connections?
Also take a look at this link
Steel connections types not visible in the dialog box or SQLDumperExe window opening and closing in ...
Jay Colcombe
Autodesk Certified Instructor
Message 4 of 8
angelapd828
Observer
Observer
Excuse me, but what content are you referring to? I've already tried the link and even tried formatting my laptop after attempting to download various Autodesk resources, such as Advanced Steel Connections 2026 and Content English 2026. However, none of these solutions have worked, which is why I'm asking here.
Message 5 of 8
ahmadaditrapsilo
Community Visitor
Community Visitor
I also experienced this and it didn't work
Message 6 of 8
jay_colc
Try the following;
Steel Connection database or menu is empty in Revit
Revit 2025 – Steel Connection Details Not Listed or Unavailable! – ARKANCE UK Community
Jay Colcombe
Message 7 of 8
lauri_barnhart
Hello, @angelapd828 and @ahmadaditrapsilo,
Just checking in—did the last response shared by @jay_colc help clarify your question?
If so, please consider clicking the "Accept Solution" button. Doing so helps others in the community find answers to similar issues.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Lauri | Community Manager
Message 8 of 8
danielapradoDR3CS
Community Visitor
Community Visitor
Hola, tengo el mismo problema,
no he podido usar las conexiones predeterminadas,
alguien me puede ayuda por favor !!
Gracias gracias
