when making slab area reinforcement, as shown on the attached picture, I want to make hook only on one side on the rebar (see blue rebar on the picture). However in properties panel the hook at start/hook at end is with light colour and doesn't let me change the property of the hook.
How can this problem be fixed?
Solved by jamess166. Go to Solution.
Hi @Anonymous
Those bars have greyed out properties because the Area Reinforcement sets the parameter values.
You can select the area reinforcement and choose the hook at start / end as desired.
This will change the property for all rebar generated by it.
You can select the area system in any view (plan, section or 3D)
