problem while inserting cad file into revit
Message 1 of 13
hello everybody >
i have a problem that is facing me , while inserting cad file into my revit ,
the problem is :
whenever i insert cad file , and after browsing to my cad file , an error message appears ,
Replies (12)
Message 2 of 13
A_MAQ
did you check VV
Autodesk Expert Elite
Message 3 of 13
-FDC-
Check the Site plan
Message 4 of 13
@A_MAQ wrote:
did you check VV
it is already checked , but what is halftone
Message 5 of 13
@-FDC- wrote:
Check the Site plan
what is site plan  ?
Message 6 of 13
A_MAQ
you are now in 3D view , and when you inserted you did not uncheck the (current view only ) option if you want to see it in 3D
go to plans and you will see it
Message 7 of 13
A_MAQ
Halftone is a visibility setting where you can see elements transparent
Message 8 of 13
what i have done is that , i inserted cad file in a plan  , not in a 3d view , and also , i unchecked current view only
Message 9 of 13
A_MAQ
if you have screen recorder , could you please regeister the process of inserting cad,so i can see the problem
Message 10 of 13
-FDC-
Message 11 of 13
ennujozlagam
@Anonymous hello you can try this simple screencast link cad into revit. thanks
Message 12 of 13
A_MAQ
hi @Anonymous,
what exactly was your problem ?
Message 13 of 13
@A_MAQ wrote:
hi @Anonymous,
i opened a new project not a template ,,,,  while inserting cad file ,,, cad file appears only in 3d view not in any other floor plans <<<<
i made a video ,,,,, but have a problem while uploading it
thanks in advance for your interest
