priority when drawing object lines in Revit
4lrdyD
4lrdyD
In the attached image, I want to prioritize the column lines (cyan), but the green lines (foundation) take priority, how can I handle this ?, This in a plan view.
L.Maas
I can think of two ways to do it.
1-Use the linework tool. However this is a manual process you have to do for each column in each relevant view.
2-Set the discipline to something different than structural (e.g architectural, coordination).
This probably will mean you have to make some different settings for other elements in your view
So you have to decide if it is worth to do and which method suits you the best
Louis
Please mention Revit version, especially when uploading Revit files.
4lrdyD
Thanks L.Maas for responding, but using the linework tool, is there a way to do it while keeping the style?, changing the discipline there were no differences in my model.
Karol_Piroska
I'm probably missing smth, but do the column lines not take naturally priority over the foundation line as the col cut line is above the foundation outline? If not for some strange reason, maybe you can set the col cut line weight than the foundation outline to "cover" it.
