Printer errors while exporting the NWC files
Amr.AbdelHai
Amr.AbdelHai
I am facing a problem while exporting NWC files from the Revit file using Revit 2020.
I have linked 14 Revit files to a hosting file for exporting NWCs of specific views. However, I am continuously receiving a lot of errors related to printer settings during the export process. Though these errors do not affect the NWC process, it is time-consuming to keep dismissing them by clicking the close button.
Elmoataz.Bellah.Salem
  1. @
Elmoataz Bellah Salem
AEC Technical Specialist | Autodesk Expert Elite | Autodesk Ambassador Gold Level | ACP | ACI
@Amr.AbdelHai
I think it is still known issue in Autodesk
According to this Link
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Error-Printer-cann...
imustafa_adel
It's a common warning message which has no straight forward solution at the moment, the printing setup with same name appears in the warning message somehow raises a warning while exporting NWC file.
The work around solution is simply to delete the printing setup with the same name from the file and from all the links as well if the printing setup exists as follows:
Regards.
Mustafa Adel
AEC Software Developer | BIM Specialist.
