Print to PDF Issue
Print to PDF Issue
Print to PDF Issue
Hey guys,
Appear to be having an issue with my REVIT LT 2015 version. I also use Autocad 2015 and dont have this issue.
When i go to print to PDF it does not give me the option to print to anything bigger then A3. Autocad virtually does the same procedure to print to pdf but it gives me the option to print A2,A1 etc etc....
Is anyone aware of what could be causing this issue?
bjoern_teutriene
Hey,
generally sheet sizes should be a printer configuration and should be the same in all programs. Maybe you could try another pdf printer like this one:
http://www.pdfforge.org/pdfcreator
Beste Grüße
Björn
Senior BiM Consultant bei
www.bimotion.de
E-Mail | LinkedIn | YouTube
RDAOU
Hello @Anonymous
Make sure when you print from Revit that the proper PDF printer is selected and insure that you have the latest driver installed.
