Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
POST TENSIONING REVIT FAMILY
12 REPLIES 12
Message 1 of 13
6055 Views, 12 Replies
Hi all,
I am after some post tensioning families. Any idea where I can find them from?
I am modeling this PT slab which has straight tendons, so I don't need to use plugins like Sofistik or any complex methods for creating them. A straight rebar would do the job.
However I need some families to show the anchorages of the PT system.
Any help, would be appreciated.
12 REPLIES 12
Message 2 of 13
Tom_Kunsman
If you look around the internet you will see that there are very, very few floating out there. The best ones I have seen people do not want to share the family, which I totally understand. The complexity comes from the number of "drapes" that the tendon might have - which depends on framing and rebar placement.
If you don't need the drapes it is an easy thing to make.
Message 3 of 13
ovidiu_paunescu
Hi @Anonymous
You can use rebar (free form or shape driven) to model the tendons and Rebar Couplers to model the anchorages.
Rebar Couplers can have any geometry defined in the family and automatically align to the end of bars.
Free form rebar can have any geometry and can be generated manually by defining some structural host with the desired shape or by using dynamo to directly create the tendons from generated curves.
Defining the bars manually has the benefit that bars automatically adjust when adjusting that custom host.
Here's a simple model in place example of this with bars following the spline face and couplers as anchorages.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Message 4 of 13
in reply to: ovidiu_paunescu
Hi @ovidiu_paunescu
Thank you for the response. I created the PT live end using the coupler family as you suggested and I am happy with the result.
(Picture 1)
The only problem now is that it looks like plan in the sections, instead of showing from side (I am assuming is a property of coupler family). Any ideas how I can change that?
Picture 2: How it currently looks like in the section
Picture 3: How I expect it to look like
(Picture 2)
(Picture 3)
Message 5 of 13
zaheer_zedcon
That's look awesome can you please send me the family here my mail ID: hussainsam44@gmail.com
Message 6 of 13
davidpenilo
any chance you could send me this too? pretty please!! robbenronaldo@gmail.com
Message 7 of 13
davidpenilo
any chance you could send me this too? pretty please! robbenronaldo@gmail.com
Message 8 of 13
Hi @ovidiu_paunescu
I've come across this thread when I was looking for a way to model banded PT cables and I had a question on how one would go about modeling the splayed ends for cables.
Draping seems relatively straight forward, but when cables start "traveling" upwards on the drape and have to spread out to match anchorage spacing at the slab edge, it becomes quite unmanageable for me.
Any ideas/pointers?
Thanks!
Message 9 of 13
tytheara104
how i get this family sir..?
Message 10 of 13
trantu2002us
Could you show family Pan, live, dead and coupler? Thank you so much👌
Message 11 of 13
preetham_kaja
Hi great for your efforts for Live Ends you prepared a coupler family then what about Dead End? Did you prepare Dead Lockbubble? For LOD 450 level of working you have to update chairbars. Also, one question, you should duplicate a number of strands in this Tendon Coupler family as per the required number of strands. Are you working accordingly??
Message 12 of 13
Abe728282
Can I get this family?
Here is my email Abe728282@gmail.com
Message 13 of 13
20149294
Hi sir, how can I get your family ? Please contact to my email: anhduc2569@gmail.com. Thank you so much !
