Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Phantom sheet that I can't get rid of
5 REPLIES 5
jrayhorn
1239 Views, 5 Replies
Revit 2020.
Using a template given to us mandated by the project owner, I have come across a phantom sheet. By that, I mean that it shows up in the Sheet List schedule, but does not show up in the Sheet Index schedule or the actual list of sheets in the project browser (see screenshots).
I can rename the sheet in the Sheet List schedule (which you can see, I have done) and the fields for the Index & List are the same & checkbox for itemize all instances are checked in both.
If the sheet exists, why doesn't it show in the project browser? How can I delete this phantom sheet? The client has a number of QC checking softwares (etc.) that will surely turn this up as an error when we go to submit.
Can anyone out there help with this? We are completely baffled by this.
Please & thank you in advance!
5 REPLIES 5
L.Maas
in reply to: jrayhorn
Duplicate post. See other thread HERE.
Louis
Please mention Revit version, especially when uploading Revit files.
jrayhorn
in reply to: L.Maas
Very first line says Revit 2020, but it's 2020.2 to be exact.
jrayhorn
in reply to: L.Maas
Not sure how the double post happened.  How can I delete the other post?
L.Maas
You can not. System does not allow deleting threads/posts
Louis
jrayhorn
Solution found in another Revit forum.
The Answer
Autodesk reference
Forma Design Contest
