Parametros combinados en una tabla a IFC
aragoneH2UNL
aragoneH2UNL
Hola a todos,
Tengo un campo en una tabla que es una combinación de varios parámetros y veo que no se puede exportar a IFC. ¿Cual sería la mejor manera de hacerlo? Se puede crear otro parámetro y asignarle el valor de la tabla?
Gracias de antemano,
Saludos
Eva
L.Maas
Probably easiest way is to create a Dynamo script.
-Create a new project parameter for the combined code.
-Add this project parameter to all relevant categories.
-Create a script to read all the code parts and join them together with Dynamo and then push the combined code back to the new parameter.
After that you can export this new parameter to IFC.
Louis
Please mention Revit version, especially when uploading Revit files.
aragoneH2UNL
Thanks for your quick response. I was afraid it was going to be with Dynamo 🙂
L.Maas
It is not difficult to do with Dynamo...concept:
Needs of course to be modified for the type of elements and your parameter names.
Louis
aragoneH2UNL
Hi Louis,
Thank you very much for your time, I'll try to modify the script for the rest of elements. I greatly appreciate your support, its very good for me
