We use the pin tool to avoid accidental moving of objects already placed. The beams producing the issue are concrete double t beams that go under a concrete floor. All of them could be pinned just fine and as expected. One of them moves an indeterminable amount to the right and in positive z-direction. Has anyone else run into similar behaviour? The incident occurred in Revit 2024.3, the model is around the internal origin well within the 20 miles range. The nudge, as though somebody was hitting the cursor keys, would not have been noticed if the user had not used an absurd magnification.
Unpinning the beam after it was mis-adjusted by the pin command, allowed to move it back to its original position - only to be immediately moved again when trying to lock that position again.
