Not showing the right colour of the material
Hello, the material of this topographic surface is grass (which is obviously green), although, in the 3D view it shows like this do you know whats going wrong???
Mohamed-Nassar
Check the asset of the this material to check it's visibility.
https://www.youtube.com/watch?v=PXaIW24Gzko
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
L.Maas
A material has two tabs related to colour of your material, Graphics and Appearance.
The settings in Graphics are used when view is in Shaded & Consistent Color mode. The settings in Appearance are use in Realistic mode. The standard grass material of Autodesk contains black and green pixels, resulting in a dark/black looking material when looking from far distance in realistic mode
Louis
Please mention Revit version, especially when uploading Revit files.
Whatever material i put it shows up like this.
DIDNT WORK
Whatever material i put shows the same
