node connection
node connection
node connection
Hello to everyone,
I am at the moment having some doubts about the node connection between the beam taht is being shown at the picture and the retaining wall. Is this the ritgh way (See picture "node connection")? I have been doing this way... see picture (node connection 2)
BEST REGARDS
Luiscko
For construction model is ok the second one but if this model will be use for structural analysis you need to connect your wall with your beam and check if your analytical model connect correctly.
Luis Rodríguez
BIM Manager | Digital Transformation Lead
alt="EESignature" width="244" height="22">
Your Name
Encontraste util este post, compartelo y dale like para que llegue a mas personas como tú.
Si tu respuesta fue solucionada, te agradecemos que des click en el boton SOLUTION.
