Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
New Revit 2022 - Missing Templates
3 REPLIES 3
ranesc
699 Views, 3 Replies
I am using the new version of Revit 2022, and can't seem to locate the template files that I could select from when beginning a new project.  I've already gone through the process of downloading and installing the Revit content using the "Load Autodesk Family" button.
Here is what I have so far.  This box was blank after loading the content.  I went through a few steps to get the template shown, but it's not the same template as what was included with Revit 2021 or earlier.  I'm looking for the Imperial Construction, Architectural, Structural, and Systems templates.
Any thoughts?
thanks,
Chris
3 REPLIES 3
RDAOU
in reply to: ranesc
@ranesc
Templates and contents need to be downloaded and installed separately ... download link below
Autodesk Revit 2022 Content | Revit 2022 | Autodesk Knowledge Network
ranesc
in reply to: ranesc
Yes, I went through the steps to download the content.  I have all of the families installed.  The problem is I do NOT have the Imperial Structural Template that I used to use with the earlier versions of Revit.
When I start a new project, I am greeted with the following image.  The template there is not the same template as the structural template I'm asking about.
ennujozlagam
in reply to: ranesc
you can refer here
https://knowledge.autodesk.com/support/revit/learn-explore/caas/sfdcarticles/sfdcarticles/Installing...
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Revit-Te...
https://knowledge.autodesk.com/support/revit/learn-explore/caas/sfdcarticles/sfdcarticles/Manually-i...
