Hi,everyone
I wanna know why my Temporary Dimensions looks like this
I want it looks like this
how can i make it right?
Solved by hmunsell. Go to Solution.
Solved by Alan.johnson1970. Go to Solution.
Drag the witness line, to where you want it to be.
You use the blue dots to drag the witness line, it will highlight the new faces as you drag.
interesting.... is that the extent of your content? i looks like it is aligning the dimension to something below.
Howard Munsell
thanks for your reply.
I think just my project have some mistake after i open a new project then don't have this problem anymore but still thank you so much.
