Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Multi-Rebar Annotation not selecting slab rebar in plan
7 REPLIES 7
Message 1 of 8
1111 Views, 7 Replies
Hi, I am using Revit 2018 student version.
I have done the rebar as per the below pictures (I did not use Area Reinforcement for slab because I wanted to be able to customize exactly where the rebar ends, etc.). Now when I try to detail the slab with multi-rebar annotation in the plan view, it does not register. It is as if there is no rebar there but there is rebar throughout the slab.
How can I use multi-rebar annotation to detail the slab in the plan view? Or is there another more efficient way? The cross section is also shown for your information.
Labels (2)
7 REPLIES 7
Message 2 of 8
_Vijay
it's supposed to show, did you check in visibly?
Message 3 of 8
in reply to: _Vijay
What do you mean? It doesn't even allow the rebar to be selected for the
annotation.
Message 4 of 8
ovidiu_paunescu
Can you add a sample file?
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Message 5 of 8
in reply to: ovidiu_paunescu
Hi there, please see attached sample file.
My query refers to the 00 - TOS Rebar View.
Message 6 of 8
ovidiu_paunescu
Hi @Anonymous
I don't have Revit 2018 currently installed, but it seems to be working in Revit 2019. Can you try a newer version and see if it works for you?
Message 7 of 8
khiem.tt
Just select "Aligned Multi-Rebar Annotation". See the attached pictures
Message 8 of 8
in reply to: khiem.tt
Thanks, this works. Never used aligned before so did not think of it.
