Mult-Rebar Annotation orientation
sohailhawk86
sohailhawk86
Dear Fellows,
Can you please guide how to show/ orient the multi-rebar tags for rebar. Image is attached for reference.
ovidiu_paunescu
Hi @sohailhawk86
Just select the tag inside the MRA, by pressing Tab when hovering the cursor over it, or select the MRA and click the Select Tag command in the ribbon.
Then for the tag, switch from vertical to horizontal
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
sohailhawk86
Thanks. It worked.
sohailhawk86
@ovidiu_paunescu
Can you guide me how to select each face rebars in wall elevations. I tried in revit but I can only select one face. My whole intent is, I want to show each face rebars with single tag and leader line.
