Modeling Structural Wall Assemblies- Structural wall cores only?
I am starting to build out some standard families for my company's content library. While some of the structural elements are pretty straightforward, I've come to a halt with wood framed walls. Currently our firm only 2D drafts using CAD backgrounds and our drafters either ask for the backgrounds to be exported from Revit showing only structural wall cores or they manually delete any non-structural wall layers in CAD.
We want to eventually switch over to Revit so I've been trying to think of the best way to approach this. I'm considering just modeling the the stud/structural sheathing in our internal wall assemblies. When I copy monitor the design model over into our template then I can essentially just replace the architects walls with our structural framed walls. I'd retain the fire rating, wall function (interior or exterior) and general sizing information in the type name.
I'd love to understand from anyone else's perspective if this makes sense or if there would be any possible issues down the line by only including structure layers. The only issue I can maybe see is if there is a structural façade like brick that would then have to be manually offset from any exterior studs? I am the only person at my company using Revit currently so I don't really have anyone to bounce ideas off of internally.
Thank you!
