Hello everyone, I don't use structure very much so this may be simple and I apologize. I am trying to simply connect an HSS tube to the side of another tube with a 45 degree miter and weld joint. I cant figure out how to put the miter on the smaller to to place it on the side of the the larger tube.
Solved by ToanDN. Go to Solution.
Use Cope Tool: select a HSS, click on Cope icon from the ribbon, select the HSS to be cut, select the other HSS, finish.
Another crude way ,draw a reference plane where you want to cut the HSS and use Cut geometry to cut the HSS with that plane.
