Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
miter HSS tube to side of another HSS tube
2 REPLIES 2
987 Views, 2 Replies
Hello everyone, I don't use structure very much so this may be simple and I apologize. I am trying to simply connect an HSS tube to the side of another tube with a 45 degree miter and weld joint. I cant figure out how to put the miter on the smaller to to place it on the side of the the larger tube.
2 REPLIES 2
Use Cope Tool: select a HSS, click on Cope icon from the ribbon, select the HSS to be cut, select the other HSS, finish.
Another crude way ,draw a reference plane where you want to cut the HSS and use Cut geometry to cut the HSS with that plane.
rprivittB3TTG
The coping tool is giving me the same message.
Forma Design Contest
Technology Administrators
