Missing ifc model elements
abajenov
abajenov
Ladies and gentlemen, please, help me!
Our colleagues kindly provided us with an ifc-model of gangway. Unfortunately, some elements are lost, when I  insert the file as a link in revit-project. I've made screenshots, so you can see the difference. The first one is the ifc file opened in BIMvision. The second one is the link inserted in Revit. I also captured table with properties of one of the missing elements.
P.S. The original model was made in Tekla. That's all I know about it.
jay_colcombe
This appears to be a common issue whereby you have to include additional items of set a specific export view compatibility setting, i know in Revit to IFC Property Sets are often missed out and needed.
Hopefully this will help although more related to Advanced Steel.  One thing to not here both the L Angle and Box Section are missing so could they have been combined to make a composite section?  and this is what is causing the issue?
IFC exported from Tekla Structures missing elements when importing into Advance Steel (autodesk.com)
Jay Colcombe
Autodesk Certified Instructor
