Hi all
I discovered some weird behavior of rebar tag when coping or mirroring them in Revit v2020.
-> The rebar tag is place far from its original position
The behavior is better in Revit v2019 this means something got f*ck*d up v2020.
See screenshot
Easy to simulate in v2020. Not fun to deal with
Solved by pieter.zeenaeme. Go to Solution.
Could you please add the simple model from your picture?
I can only seem to reproduce this issue when tagging a bar in a varying rebar set.
Ovidiu
First of all thank you for replying.
I added 2 models (1 Autdesk 2020 and 1 firmbased template) to this link.
In both of them I reproduced the issue.
It is really undermining our workflow now.
Many thanks for your effort
Grtz Pieter
