I detail precast concrete which always have a shim space between wall panels and footing. The standard gap that we use is 1" for shim and grout and I use a wall with a "grout" type so that I can place the footing below the panel. If I sent the bottom of the wall at the footing and the top at 1" above the footing I get the attached error. The wall is set as 1" high but Revit says that the top is higher than the base. Is there any way to make a 1" tall wall?
