Metric Rebars
Metric Rebars
muhammad_farhan256
Metric Rebars
muhammad_farhan256
I am looking for the rebars in revit named as T10, T14 and so on with the prefix of letter ''T'', as well as Ø10, Ø14,Ø22 and so on, with the prefix of symbol "Ø" using metric system. But I'm getting the bars named in revit as H10, H12, H15,
For better understanding I'm attaching the drawings and highlighting the required rebars.
Thanks, looking for the optimal solution.
Note: first 2 images are my requirement regarding rebars, and 3rd the screenshot of revit shows the rebars i'm getting from it.
Ahmed_Muharram
you can find it in the Egyptian library as T & R you can download it here for revit 2021 and 2020
or you can add it yourself by clicking on STR tab -- rebar --- Edit type and then duplicate and add all the diameters you need and you can name it T or even diameter symbol also you can modify the tags to get the shape you want in the sheets
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Ahmed_Muharram
check this screencast
Ahmed_Muharram
did it work with you?
muhammad_farhan256
Yes, your solution really worked, thanks alot. 😁😁👍👍👍
