Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Massing showing for some objects but not all.
1 REPLY 1
386 Views, 1 Reply
Hi I am having an issue with massing for a bridge design that I am working on. I need to simply put glass on a gradient surface. while I duplicate and move the masses into they're proper location they show up in the 3-D model as well as the elevations but in the plan view only some of the panels show up. My view plane is set so these all should be visible and the transparency is set to 40% so they are all visible, or should be. It is seemingly in a random pattern and when I redo it these sections will not show up. Any help is greatly appreciated
1 REPLY 1
MostafaElashmawy
I think it's the view range.
if possible please share the file.
Mostafa Elashmawy
