Manipulating scale to fit your sheet
glkirk
Message 1 of 1
glkirk
Are you tired of working so hard to make your elevations (or any views) fit on your sheets decently? Changing the arrangement over and over, changing the size of your sheet or even adjusting your title block because you need just a bit more space?!
If it is not that important, you can adjust your scale the little bit that you need and then check "Display name" and type in your proposed scale.
Hope this helps someone.
Replies (0)
