LOOKING FOR EASY WAY TO IMPORT SHEET FRAME TO REVIT
A_MAQ
Advisor Advisor
A_MAQ
I have sheet frame in CAD i want to export to revit
but the problem is the pictures (ex.the logo of company ) are not imported
how can i find a way to do that??
thanks in advance
Autodesk Expert Elite
constantin.stroescu
I suppose the Logo is an imported bitmap in AutoCAD.....If you want this to appear in your Revit file then ,in Import dialog, check the option Current View Only
Constantin Stroescu
A_MAQ
i did that
but no effect
constantin.stroescu
if the logo is in Layout view and not in Model view of AutoCAD, then it must be imported into a Sheet , not in a View....
Constantin Stroescu
A_MAQ
i have imported to sheet not view
and it's the same no effect
constantin.stroescu
Have a closer look at your attach file in AutoCAD. If it is a .pdf file then could be an explanation, because Revit doesn't recognize .pdf.
In this situation change the .pdf format into a bitmap type, something like .png or .jpg and then reinsert it into AutoCAD . Exported into Revit it will be recognized....
Constantin Stroescu
