Linked IFC Files
Linked IFC Files
Flies-Eyes
Advisor Advisor
Linked IFC Files
Flies-Eyes
From articles that I have read, Revit 2026 had new features to include improved interoperatbility. The known issue is that when linked files are updated, the dimensions associated are lost.  Was this 1 of the improvements that were made with 2026?
I have tested but I have yet to see the dimensions sticking to objects when objects change with updates.
Has anybody successfully solved this issue.
jay_colc
Doesn't appear this way but the advised workflows may resolve it?
Dimensions attached to objects in linked models lose host in Revit
Jay Colcombe
Autodesk Certified Instructor
Flies-Eyes
That is possible.  I will need to test.  Do we know if this only works in 2026 or should this work in 2024 as well?
GCFEL
IFC export settings is important.
Flies-Eyes
Still no luck with retaining dims when IFC is updated.  I noted it mentions to keep the guids the same.  If a new IFC is created ftom tekla or archicad new guids will be assigned to elements.
I am linking the IFC to the master host file.  Is this where I am going wrong. Do I need to create a separate rvt file to link the IFC then link that rvt file to the master model?
